Front Control Arm Geometry
Old Jul 24, 2011 | 07:05 PM
Sahara Lee's Avatar
Default Front Control Arm Geometry
AEV recently released their geometry correction front control arm brackets:
http://www.quadratec.com/products/16502_4300.htm
Rancho's Sport Lift has always included similar (but 1 piece) control arm lowering brackets:
http://www.quadratec.com/products/16031_30X_A_PG.htm
Besides lower arm bracket clearance over rocks, are there any other down-sides to these brackets?
Is there an advantage to using these brackets versus putting in adjustment cams? I heard the cams don't hold castor very well over time (and bumps).
Both manufactures claim better ride over bumps from reduced control arm angle. I know replacing the control arms with adjustable ones is the optimal solution but, I don;t want to spend over $2k. (In fact with current Rancho $500 rebate I can get their lift kit with RS9000XL shocks for just over $600.)
Anyone have experience with either or both arm lowering brackets?
Cheers!
Old Jul 25, 2011 | 09:11 AM
nthinuf's Avatar
Both are very popular, and a quick search will bring up lots of info on them. I haven't seen a direct comparison between just the CA brackets, but for the price difference on the complete lifts, I would definitely go with rancho. Why spend an extra thousand dollars for a bunch of brackets?
Other than the loss of ground clearance, the big negative to me would be the complete lack of adjustability. Add bumpers/winch/tire carrier/etc, you lose an inch of height, your caster changes, and you have no way to set it. Same with adding coil spacers for a little more height. And then there is pinion angle. How do you adjust it when you swap your factory driveshafts for aftermarket double cardans? (you can't...)
You will get a lot of positive reviews from people that have these lifts, just food for thought.
Old Jul 26, 2011 | 03:34 PM
daspes's Avatar
The purpose of the brackets and adjustable control arms are not the same. The brackets are designed to change the geometry of the lower arms putting them at a similar angle of a long arm.
As for loss of clearance, I've never had an issue.
Old Jul 26, 2011 | 03:48 PM
Jumpbail's Avatar
I installed AEV 3.5 on my 2011 Rubicon and didn't do steering kit at first. After bump steer etc...I installed AEV steer kit, and its awesome. I was amazed at the bushings that were wearing already before I did steer kit. Scary!! No loss of clearance.
