Front drive shaft boot
How important is the front drive shaft boot? I tore about 1/4" off today. Should I even try to get it covered under warranty? I do plan to get an after market shaft one day soon.
Thanks
Thanks
You have a couple options. A used driveshaft or a new one from J.E. Reel, Tom Woods, Teraflex, Rubicon Express, or any of the other manufacturers that sell them. Sounds like you are going to need a set of adjustable upper arms in order to keep this from happening again.
Ty
edit: Its not a warranty issue. More than likely your lift caused it due to the angle the shaft now runs at.
Ty
Thanks
You must have an 07. I got mine covered after it ripped thanks to the fact that the part number for the 08 changed. They actually changed the clamp that holds the boot on in 08. it is now flat instead of the typically screw. After mine was replaced it hasn't hit the oil pan yet. Now i did break my axle housing and got hosed with a hefty bill but im pretty sure it had nothing to do with this.
