Front drive shaft recommendations
Just had a service at dealership. I went to grease fittings and realized front drive shaft seal is starting to spray.
Was looking at Tera Flex shaft since I have TF lift & control arms.
-Any pros/cons of the TF shaft.
-Any other recommendations.
-Any dos/don'ts for installation.
SPECS 09JKU on 35s with TF 3" lift & adj. arms, & 1" body lift.
Was looking at Tera Flex shaft since I have TF lift & control arms.-Any pros/cons of the TF shaft.
May I suggest a Coast 1310? Ive read and done my research on it and it seems to be a quality driveshaft which should last many miles. Teraflex is fairly new to the driveshaft world, so there isn't much on them that I know of...
the shaft doesn't come with u joints? need 2?
shafts come in oe replacement and 4-6" lift should i get the 4-6" just in case go with a bigger lift later?
