front end alignment maybe ?
Looks like you just need to adjust the drag link. If you aren't familiar with everything under your Jeep, probably worth a trip to the alignment shop. They can confirm that you didn't bend the tie rod or anything like that.
What didn't work?
Go up to Write-ups, at the top is a link to an index, open it and scroll down to either the Steering or Troubleshooting sections, click the DIY Alignment writeup and follow the link. It has steps for several of the basic alignment procedures. For this, loosen the two bolts and twist the turnbuckle. From your knees, you may be able to see the steering wheel turning. If not, twist a bit then go look.
