Front end really squeeky/creaking all the time
Old Jul 16, 2011 | 05:50 PM
Trauma's Avatar
Default Front end really squeeky/creaking all the time
Seems to progressively get worse.
Ive had my lift for maybe 2-3000 miles now.
rock krawler springs/trackbar
Rough Country discos
Bilstein 5100s
It just seems to always sound really squeeky and makes these creaking noises. I torqued and re-torqued everything... I don't understand what It could be but I worry it will lead to a failure someday.
Old Jul 16, 2011 | 07:09 PM
4WHLN's Avatar
I have JKS discos and from time to time they work themselves a little loose. When they do they squeak. I also had a factory front shock come loose and make noise when i would hit a bump. I would double check all bolts again and make sure they are tight.
Old Jul 17, 2011 | 06:34 PM
Trauma's Avatar
I cant figure this out... I discoed the swaybar no fix.
If I stand on my steps and rock the boat really hard, it makes the noises too. So obviously its suspension related.
I just really worry damage is occurring. I did a visual and no welds or anything appear cracked. It sounds like a creaking noise from the springs... ?
Old Jul 17, 2011 | 06:35 PM
Hskr4x4's Avatar
Money says it's the rough country or the spacers
Old Jul 17, 2011 | 06:39 PM
Trauma's Avatar
Spacers? what spacers?
The rough country discos are actually pretty solidly built... I think?
Old Jul 17, 2011 | 06:44 PM
Hskr4x4's Avatar
Your factory spring spacers. Also make sure your springs are sitting in correct position on bottom.
Old Jul 17, 2011 | 07:00 PM
Trauma's Avatar
They have spun off the little notch they sit in in the past.
I guess it might be time for some spring clips?
I don't see any spring spacers in there... just the bump stops?
Old Jul 18, 2011 | 06:24 AM
HG07JKRubi's Avatar
trackbar bushings ? I had an issue with a FT trackbar that made horrible squeaking sounds just as you explained. Filled the bushings with grease and noise went away.
Old Jul 18, 2011 | 07:39 AM
geoffcwilson's Avatar
Since you can reproduce the sound by rocking, you need to enlist the help of someone to rock your Jeep while you look for the source of the sound. I did same recently and found loose sway bar links. Tightened and have been good since.
Old Jul 18, 2011 | 04:51 PM
Trauma's Avatar
Ok, so this noise is definitely coming from the upper portion of the springs. (90% certain)
all 4 of them, front and back.
If i rock the front bumper/rear bumper, you get the point.
The springs are REALLY creaky/squeaky whatever you wanna call it. They are the Rock Krawler stock mod springs, (2.5") supported by bilstein 5100 shocks.
They are all perched correctly I just don't understand. They are 4000 miles old. Is this normal? Should I call Rock Krawler about this?
I still cannot figure out what makes the REALLY loud snapping noise every so often when I hit the brakes hard.
