front gear install gone bad
so i took the jeep to the dealer to get some new gears installed(5.13"s)the rear end went together with no problems but the front end apparently needed 40 thou worth of shims to get it to mesh right and when it was put back together and roadtested the locker or 4x4 light was flashing because it was shimmed so far over it was activating the sensor,so now i get a bill to take it all apart and see what the fuck,can anyone shed some light on how this sensor works or if this even makes sense.thank you
BTW, what ever gave you the idea that a Jeep dealer was competant to do this job? A dealer would be the LAST place I would ever want to do a regear. And if he did it in house and didn't sub it out to the local driveline shop he is an idiot.
Does the locker lock? Does it unlock? Put it in 4Low and drive in some circles on blacktop and you'll be able to tell if it locks. The light should be on steady. Then unlock it and drive in the same circles and see if it unlocked. If it unlocked but the light is flashing it is a sensor problem that they should be able to fix easily as WOL said. Anybody that has done a few of these would now how to put one together without having this problem. Yes that is a slam at the dealer.
no it's not right at all but they kinda got me by the nuts,i could freak out and not pay but next time i go in for something it's gonna be the lift caused this the gears caused that or someother crap that makes them deny warranty.
As an aside your diff was probably the first one the dealer ever had apart. You were paying him to learn. And now he wants you to pay to fix his mistake. Amazing!
