Front LCA Length
Old Jul 29, 2011 | 02:30 PM
RubiconRod's Avatar
Default Front LCA Length
I've seen different numbers thrown around in various threads on what length to set the front lower control arms prior to initial install. I realize the end result is achieving the correct caster but I would prefer not to have to install then remove then install, etc. Would like to get close enough first time around. 23 inches eye to eye seems to be what i need? I have a full traction 3 inch lift. It netted closer to 4 inches in front though. And just to confirm, I'm shooting for caster between 4.5 and 6 correct? Still running stock wheels/tires w/spacers.
Thanks!
Old Jul 29, 2011 | 02:32 PM
mkjeep's Avatar
23in eye to eye is a good starting point. Set it there , drive it and see how you like it.
Old Jul 29, 2011 | 02:34 PM
mkjeep's Avatar
If you feel it is still abit flighty, increase in 1/8in increments and test drive.
Old Jul 29, 2011 | 04:56 PM
RubiconRod's Avatar
Thanks for confirming!
Old Jul 29, 2011 | 06:30 PM
Yamaha90's Avatar
i recently heard that the driver side should be a tad shorter because if they are equal length it will cause a u-joint in the front to bind? is this true?
i'm going to adjust mine tomorrow when i put on my 3/4 inch spacers giving me 3 1/4" lift in front i used to have a little vibration at around 50mph, then i brought the arms back giving me about 4.5-5 caster and i still barely have this going on. i might give the drivers side one less rotation or so.
Old Jul 29, 2011 | 06:34 PM
mkjeep's Avatar
Um, haven't heard that one.But some adjust the passenger side abit longer to help correct a pull to the right if you have one. In fact my pass side is set 1/4in longer. But , when i was running a shorter lift, they were set evenly cause I didn't have any pull.
Old Jul 29, 2011 | 06:43 PM
RubiconRod's Avatar
Interesting. So I have a sight pull to the left due to my bilstein SS. Should I try to compensate for that or just make my arms the same length?
Old Jul 29, 2011 | 06:48 PM
mkjeep's Avatar
Try same length first, if you still have a pull to the left, lengthen your driver side by 1/8in and check, go from there.
Old Jul 29, 2011 | 07:47 PM
Yamaha90's Avatar
i don't have any pull at all, maybe i'll just leave it. It's not very noticable at all..
Old Aug 2, 2011 | 05:24 PM
RubiconRod's Avatar
So getting ready to have the lower arms installed tomorrow. Asked my installer to do 23 inches eye to eye. Here's the interesting part, using a tape measure, my factory arms are already 23 inches eye to eye in length. So how will adding my adjustable arms set to 23 inches eye to eye help me?
