Front locker
Old Jan 21, 2013 | 12:44 AM
guam671jk's Avatar
Default Front locker
Hey there JK fans,
Need your help or advice once again. Just had a front locker installed in my dana 30, locker is a yukon grizzly locker. The shop here on guam told me about the abs lights and the traction lights going on when making a turn or full turn and shuting off once it drives straight.Also pulling to the right. Is this suppose to happen or is it normal with a fulltime locker.Or are my speed sensors going out wasnt like this until they installed the locker.Just wanted to know if this is normal being there is a locker in front.Thanks again jeepers your help or advice is greatly appreciated.Sincere guam671jk!!!!
Old Jan 21, 2013 | 07:03 AM
tslewisz's Avatar
You're talking about driving on-road? It should be transparent in two wheel drive; no different than before.
Old Jan 21, 2013 | 07:56 AM
Dynatrac's Avatar
Sponsoring Manufacturer
The pulling may be due to tire pressure. With an autolocker up front you'll notice pulling if the tires are at different air pressure. As for various dash lights, I haven't seen this happen with a front locker in a JK. What year JK?
Old Jan 21, 2013 | 12:05 PM
esantia's Avatar
No, it doesn't interfere with the traction control. Some noise at u turns, offroading doesn't affect the Bld. Check tire pressure, alignment or locker install clearance.
Mines a Aussie locker.
