front lower control arms with cam bolts
I have a 4 inch superlift lift and yes the cam bolts were install.
I Just received the Currie Lower control arms and was wondering if I could mark the cam bolts and reinstall them with the lower adjustable control arm. I would like to install the control arm today because it is my only day off this week. Good or bad idea any help would be appreciated
littlejon i disagree...i went with rockrawler adjustable lower control arms , and asked them this same question, they RECOMMENDED using BOTH the cam bolts and ADJ CON ARMS. reason being is that the control arms will make the major adjusments and the cam bolts can "fine tune" any needed adjusments from there. so tes you can mark and reuse them
Well I just finished installing the lower control arms. I was amazed at how easy it went together except for the lining the axle to the control arms. The measurement I used is 23 inches eye to eye. I glad I got the lower control arms are I would not have notice the Fuvk up the so called Mech. did to my Jeep.
I had the lift installed @ 4 wheel parts what a joke $140.00 for alignment. As I was installing the lower control arms (Thank WOL for the write up) starting with the passenger side I mark the cam bolt locations on both side and noticed that the J-hole who installed the lift notched out the tabs on the passenger side and did not notched out the driver-side. Both cam washers were straight up causing no adjustment what so ever. Actually this happens to be a blessing now I only have to weld the passenger side lower control mounts on the axle. From now on all my Mod's are going to be done by me with the help of this Forum!!!!! Thanks a lot for all the Help JK brothers.
