Front pinion/caster recommendations
Just had my 5:38's installed. I'm getting a slight vibration above 60 mph, (Yes, they were broke in), I'm currently running 6.2 degrees of caster and a JE Reel OE replacement front DS (re-uses the OE flanges). I removed the front DS and the vibes are gone.
Is the 6.2 degrees too much for the JE Reel DS? Should I adjust my front arms for less caster?
the high gear ratio will cause the ds to turn at a much higher rpm. which in turn will cause the ds to vibrate much more than a stock 3.73 or 4.11 would if the angle between pinion and ds is not at or near 0 degrees. plus with the adapter flanges there is more unhung weight which will add to the vibration.
Think I might try to adjust my arms and see if I can find that balance between caster and pinion first.
Why does that particular gear ratio sensitive to the pinion angle? Have others had trouble with 5.38s doing this?
negative or positive caster? What works on one jeep may not work on another. Due to difference in lift heights, type off drive shaft and gear ratios. The vibration can only be fixed by correcting pinion angle. If your not happy with handling after due to castor then you could cut and rotate c. Or get a after market high pinion axel. 4.5 degrees of castor caused vibes on mine.
Several people have used the adapter plate front ds on here have blown, cracked and or f'd the t-case up. I'm one of them. Lose the adapter one and install yokes.
