front pinion seal
Old May 29, 2009 | 06:40 PM
captjay's Avatar
Default front pinion seal
so my mechanic just calls me and says the install kit for the front d30 had the wrong pinion seal in it. is this a fluke or something, shouldnt the seal with the proper kit fit or did i not know something like hey the seal provided doesnt fit, you will have to order a different one. sorry no part numbers, he ordered everything for me. this was install of new gears and locker. im just kinda curious if anyone else has run into this when regearing. any comments welcome
Old May 29, 2009 | 07:40 PM
nangulator's Avatar
I believe there are 3 different dana 30 pinion seals used from 76 to 09
Old May 30, 2009 | 01:31 AM
jeeper93436's Avatar
it happens with everything. you should always double check your parts when you get them. good thing he notice it.
Old May 30, 2009 | 03:07 AM
Geeper4x4's Avatar
Yes, there are multiple pinion seals so it's really no big deal but can take more time to get the job done.
Old Aug 17, 2009 | 04:46 PM
arcoleman's Avatar
Where do you get front pinion seals? Help?
Old Aug 17, 2009 | 06:08 PM
BlackNorthernJK's Avatar
Try an auto parts store...maybe...but your dealer is generally a great option as much as people don't like their dealers, they can at least usually get you the right part fairly quickly...or...call Northridge.
Why do you ask?
Old Aug 17, 2009 | 06:36 PM
lv jk's Avatar
***erator
Quote"so my mechanic just calls me and says the install kit for the front d30 had the wrong pinion seal in it. is this a fluke or something, shouldnt the seal with the proper kit fit or did i not know something like hey the seal provided doesnt fit, you will have to order a different one. sorry no part numbers, he ordered everything for me."
If I am reading this right you mechanic ordered all the parts and is giving you a hard time over the wrong parts coming in? Tell him to piss off and get the right stuff in.
Old Aug 17, 2009 | 06:49 PM
arcoleman's Avatar
i have a leak coming from my right front axle. I have already ordered Superior axle tube seals and wanted to make sure there was nothing else that had to be replaced while it was opened.
Eugene's Avatar
Don't feel bad, the same thing happened to me when I regeared my axels. The shop called and said that I had the wrong rear pinion seal so they had to get the correct one. I see you have an '07 like mine and I believe that there was some confusion on the early production parts. And when you order a master install kit like I did, one part number covers all the individual components like shims, bearings, and seals. All the parts were correct for the front, and all were correct except for the rear seal.
Old Aug 17, 2009 | 09:14 PM
umm....unless your leaking out your pinion side now, then no you dont need one...you will only require the axle seals that superior provides with their axles as you already got
exactly...don't sweat it, could happen to anyone. the shims that came in my kit for my rear 44 were the wrong ones...shit happens, everything else was correct
