Front Pinion tilts down a litte.
I have a 4" Tera lift... I run 37's and it's a rubicon 4 door.
I just had JE Reel Driveshafts intalled and had the Alignment done. Caster was at 6.4.
I was taking a quick look and I think my front Pinion points down... it makes the driveshaft angle look a little extreem.
Anyone have a picture of their front pinion and driveshaft for comparison?
Thanks.
Seth
Thanks.
Seth
thats normal. If you want it to point more towards the transfer case you are going to have to set your caster the other way thus throwing out your good handling characteristics. some people run as much as 9 degrees of caster so you should be fine with 6.4.
