Front Spool With Hubs
Old Mar 2, 2014 | 07:49 PM
Maertz's Avatar
Default Front Spool With Hubs
Probably wont get a ton of help on this here but figured id check. Ive been searching pirate but as usual its both sides of the fence there.
Is anyone currently running a spooled front with locking hubs and hydro? Itd be fine on road with the hubs open. But offroad should still be steerable with hydro. I like how tough the spools are and cost wise it makes sense. I was debating slugs and a zip locker and may still do, but kind of on the fence. Any real world experience?
Old Mar 2, 2014 | 08:40 PM
Tooadvanced's Avatar
I wouldnt do a spool. Ever tried turning fully locked offroad? The hydro will turn the wheels no prob but you'll be scrubbing bad and turning radius will suffer. I cant remember if you already have hubs but if now they are about a 1300+ conversion. That cost plus a 250-300 spool and your well about a selectable locker. Go selectable imo
Old Mar 3, 2014 | 02:13 AM
olyelr's Avatar
True, but the Dana 60 he is swapping in already has hubs.
If you have the cash, I say go selectable. Otherwise, spool it and just unlock a hub in the tight sections... gets to be a pain in the ass though.
Old Mar 3, 2014 | 04:33 AM
Maertz's Avatar
I figured itd be a pain if i hit a long rocky section. I get spools for about 100 bucks though. My axles as said already have hubs. We always seem to be getting in and out of our jeeps but i can see the spool being a pain sometimes...
Old Mar 3, 2014 | 08:29 AM
You could always lock one hub to keep it "open" then lock the other in technical stuff
Old Mar 3, 2014 | 08:34 AM
Maertz's Avatar
yeah never intended to do both on the trail. im sure i should go selectable front. i may do a zip locker and slugs. but the strength of a spool and cost is nice, but i may start blowing hubs though...
Old Mar 3, 2014 | 08:56 AM
I would go with selectable all the way. Itll still scrub with one hub locked. If you have left locked and turn left with a 50/50 split tcase its going to wanna turn left faster than it should be and vise versa. Go arb and get the added bene of onboard air ;-)
Old Mar 3, 2014 | 09:08 AM
Maertz's Avatar
i already have dual viairs and a 5 gallon tank.
Old Mar 3, 2014 | 09:43 AM
Eaton electric then
Old Mar 3, 2014 | 09:56 AM
Maertz's Avatar
Eaton electric then
negative. its either a yukon spool or yukon zip locker. will most likely be a yukon zip locker
