Front sway bar issue..Need Help!!
Old Apr 30, 2018 | 11:25 AM
njdan's Avatar
Default Front sway bar issue..Need Help!!
I noticed that my front drivers side sway bar has my sway bar link pushed back to where it is just about hitting the front coil spring. Does anyone know why this might be happening or how to fix it? The first 2 pictures are the passenger side and the last 3 pictures are the drivers side where the issue is.
Old Apr 30, 2018 | 11:32 AM
DiamondDan73's Avatar
Do you have a lift? Is it possible that the camber is off and the axle rolled and is causing the issue?
Old Apr 30, 2018 | 11:33 AM
njdan's Avatar
Yes, I have a 2.5 OME lift
Old Apr 30, 2018 | 11:34 AM
njdan's Avatar
But if you look at the pictures you can see where the passenger side sway bar link bolt lines up with the coil bucket bracket perfect but on the drivers side the sway bar link bolt is pushed back further then the coil bucket bracket. If that makes any sense.
Old Apr 30, 2018 | 01:59 PM
SheepyTheJKU's Avatar
Not and answer, but mine is really close as well. I just assumed when I added the new sway bar links/discos (Tereflex) My sway bar was once again parallel and made it look closer then it had before. Interested to see what other people say, everything else is riding great I didn't think anything of it...
Old Apr 30, 2018 | 02:34 PM
resharp001's Avatar
Loved
Community Favorite
That looks weird to me.....but it's so hard to tell in pictures due to optical illusions. When I look at mine on the driver's side straight on, the bolt on the sway bar lines up almost dead center with the TB bracket. In the pictures, you're appears to line up with the rear of the TB bracket, but I really think that is due to the angle of the picture, and have a hard time imagining how that could be otherwise from the sway bar position alone.
You're working with factory control arms? No adjustable arms right?
Old Apr 30, 2018 | 03:09 PM
njdan's Avatar
I have Metacloak adj lower control arms
Old Apr 30, 2018 | 03:11 PM
resharp001's Avatar
Loved
Community Favorite
Have you measured frame bolt to axle bolt on each side to verify you have the arms set at the exact same length?
Old Apr 30, 2018 | 03:12 PM
njdan's Avatar
If you look at picture 1 and 3 you can see how the bolt on the JKS sway bar links sits about 1/2 to 3/4 further back from the coil bucket bracket then the passenger side does.
Old Apr 30, 2018 | 03:14 PM
njdan's Avatar
Yes, it almost seems like the drivers side sway bar is longer then the passenger side sway bar. It cant move because it's bolted to the front in a fixed spot there is no way to adjust it forward or backwards
