Front sway bar quick disconnects
Tomorrow I get my lift, wheels and 33's installed. I think my next mod will be front sway bar quick disconnects. I was thinking about the TeraFlex Quick Disconnects to go along with my 2.5" Teraflex BB, but they don't look as beefy as others out there. Can I install any brand or should I stay with the same brand as my lift? If I can install any brand which do you guys recommend?
Thanks.
Thanks.
That's sounds pretty good to me...no bungees is always a good thing. The only reason I was wondering about the TF is because of the pics that I've seen. They just look a little wimpy compared to most of the others.
Thanks for the info guys.
JKS Quicker disco's here. Easy to take off/store/put on.
If you don't already have them, consider extended bumpstops when you get the disco's...
I got the JKS because of the design. I don't know the design of the Tera Flex, but the JKS is easy because you remove two pins then pull the disco all the way off the vehicle. No bungees necessary. I also like the adjustability to keep the sway bar parallel to the ground.
