front track bar centering
Old Nov 26, 2007 | 08:24 AM
-MAW-'s Avatar
Default front track bar centering
was searching for an answer on this but did not find it
after how many inches do we need to recenter a front diff 2" 3" 4"
does n e 1 know
Old Nov 26, 2007 | 08:37 AM
i have 2.5 inches of lift and i needed to recenter mine
Old Nov 26, 2007 | 08:42 AM
yellowjeeper85's Avatar
dont know how man inches exactly it takes before recentering is needed, but the way i recentered mine worked perfect! when it was time to recenter and all the rest of the lift was finished, i jacked up the jeep with a highlift jack from the front bumper until the wheels hung and were no longer touching the ground. then i slowly set it back down untill the jack was no longer needed. Adjusted the trackbar to fit, and it was dead on. the jeep tracs perfectly and when using the 2x4 against the tire method to measure the distance to the flare it was exactly even. I couldn't be happier. now maybe i just lucked out, but i would imagine this would work for anyone, as by letting the wheels hang they can center themselves via gravity and then just set it back down and you're all set. but like i said, maybe i just got lucky. good luck
