Ft 2" Bb
Old Apr 6, 2007 | 07:59 PM
burg54's Avatar
Default Ft 2" Bb
Has anyone had trouble with the Full Traction 2" BB install? I am doing it tomorrow and want to know if there are any issues! Thanks!
Old Apr 6, 2007 | 08:21 PM
Rubimon's Avatar
It's straight forward. If you have problems with bump steer, just take off the front track bar bracket and try it without it. Read through the write-up for the 3" economy lift on project-jk for some helpful tips.
Old Apr 7, 2007 | 07:49 AM
burg54's Avatar
Thanks! I am heading off to put the lift on right now!
Old Apr 7, 2007 | 05:00 PM
burg54's Avatar
Default some issues with the FT 2" BB
Okay, the lift is on with little difficulty. But now, I am a little freaked out. My "ESP" and "BAS" lights are on along with the "slippery when wet" light, which I believe is part of the ESP. Is the solution to all of this an alignment job? Please advise!!!
Old Apr 7, 2007 | 05:50 PM
Rubimon's Avatar
Did you recenter your wheel. If not do so right away. Dont drive it that way or the light will stay on and you will have to go get it flashed for it to go off. Step #57 of the write up I mentioned shows you how to recenter the wheel.
Old Apr 7, 2007 | 05:59 PM
burg54's Avatar
Alright, I will do that first thing in the morning! It was only a 12 mile drive home from the shop where I installed the lift. That's not too far of a drive, is it?? Thanks!
Old Apr 8, 2007 | 03:05 PM
burg54's Avatar
Recentering the steering wheel appears to have done the trick! The ESP/BAS lights went out and I haven't had any other issues!
