FT 3" Sway Discos
Old Apr 8, 2007 | 06:09 PM
jared1843's Avatar
Default FT 3" Sway Discos
Has anyone had a problem disconnecting their sway bar after installing the quick disconnects from the FT 3" Premium kit?
The pins on one side come off pretty easily, but the other is always really tight. I also noticed that in the pictures of the kits the quick discos are curved, and the ones that came in my kit are straight. Any ideas? I've never discoed before....
Also, the sway bar itself is really hard to move to even disconnect it... is that normal?:confused:
Thanks!
Old Apr 8, 2007 | 06:54 PM
Erockhopper's Avatar
I dont have those particular Disco's, but mine are tight on the passenger side, I have found 2 ways to get them off. 1) If you have someone turn the wheels for you while you remove them you can get just the right amount of space to slide them off. 2) I carry a breaker bar to force the disco's down on to the axle on re-installation, so if you give the disco's a little tap, while they are on, they come off as well. Bottom line is they do come off you just have to put a little bit more effort than the TJ style.
