FT Track Bar Noise
Old May 3, 2008 | 07:31 PM
derekls's Avatar
Default FT Track Bar Noise
My track bar is making the famous dinging sound.......... I greased the crap out of it before I tighted it to 130 ft pds on a torque wrench...........
do I need to go tighter?
Old May 3, 2008 | 07:32 PM
Piginajeep's Avatar
Dont worry about torque. Go as tight as you can, then give it one more turn
if its a "ding" sound its not the track bar
Old May 3, 2008 | 07:36 PM
derekls's Avatar
well it may not be a 'ding' that was just my best way of describing it at the moment
there is just noise when going at low speeds on concrete road and small speed bumps and when stopping, and its coming from that general area track bar/axle....... ........ and it was not doing this before the track bar (got the OME lift installed first)
Old May 3, 2008 | 07:39 PM
Piginajeep's Avatar
thats probley it
the track bar makes noise for two reasons
#1. Its not tight enough.
#2. its not greesed.
Do these both and the noise will be gone. Make sure to use sticky greese, like White Lithium.
derekls's Avatar
I did use lithium grease, but it was red not white, it was sticky
where can I get some white lithium ...wal mart did not have it
Did the rear the same way, no noise(that i can tell, yet anyways), BUT there probably isnt as much movement either
Old May 3, 2008 | 07:42 PM
Piginajeep's Avatar
I got mine at Napa...I'm sure walmart has it
Dont be scared to greese the hell out of it
Old May 3, 2008 | 07:45 PM
derekls's Avatar
Ill go to napa monday and then ill grease her good and retighten
thanks for the replies
Old May 3, 2008 | 08:53 PM
Eracer76's Avatar
Make sure you pull the bushings out of the track bar and grease the inside of the bar before putting the bushings and sleeve back in, then grease the outside of the bushings before reinstalling the track bar.
The best thing to do though, is install a zerk fitting into the center of the bar end.
If you remove the bushings you'll notice that they are short which means there is a nice gap between them when installed, which is nice spot to pump full of grease via zerk fitting. Then the grease works its way all over and out the ends of the bushings and you'll never have to remove the bar again to re-grease it
Old May 4, 2008 | 06:02 AM
racerx's Avatar
x2, it will still make noise if you don't pull the bushings and inner sleeve a part and grease the crap out of them.
Old May 4, 2008 | 06:08 AM
BLKRuby's Avatar
Use some heavy duty grease, like axle grease, inside and out of the bushings, then go ahead and add a zerk to it just un case you have to do it again.
