FT trackbar/Rokmen Diff cover hitting?
Old Aug 18, 2008 | 09:53 AM
greggradwohl's Avatar
Default FT trackbar/Rokmen Diff cover hitting?
I just added a Rokmen diff cover up front. It sure looks like my FT TB is going to hit it with any amount of flex. Anyone have experience with this? Is there a TB with a more radical bend to handle after market covers?
OME 2.5" lift, no CAs
Old Aug 18, 2008 | 10:32 AM
Patrick @ Full Traction's Avatar
Could i get a photo of the front track bar and diff cover?
Old Aug 18, 2008 | 10:34 AM
Northridge4x4's Avatar
Sponsoring Vendor
Riddler Diff cover?
David
Old Aug 18, 2008 | 10:45 AM
Not a great picture, but I think you can see what I mean.
Originally Posted by Northridge4x4
Riddler Diff cover?
David
Correct...
Old Aug 18, 2008 | 02:21 PM
Another angle:
It appears to me more than a couple inches of flex and the TB/diff cover are going to hit.
I would prefer a "wider bend" track bar if there is one. Otherwise, I guess adjustable CAs could pull the axle in an inch or so.
Any suggestions?
Old Aug 18, 2008 | 02:24 PM
SteelMastiff's Avatar
That does look close... No clearance problems with my Currie Bar, for what it's worth!
Old Aug 18, 2008 | 02:35 PM
Sponsoring Vendor
Looks close jack up the driver side tire and check it out.
David
Old Aug 18, 2008 | 05:29 PM
David
I jacked it up as high as my jack goes with no contact. The driver front coil did not compress much though. It appears to me the TB/diff cover will contact before the bumpstops (FT 2") hit.
Old Aug 19, 2008 | 07:50 AM
Might someone have a suggestion on a front TB that has a larger bend than the FT?
To be clear, I am not complaining about the FT TB. I know you cant make everything work with everything else.
