fuel rims problem
Old Apr 15, 2014 | 05:25 PM
bigred716's Avatar
Default fuel rims problem
Alrightey then, so I just put new fuel rims on 33×12.50 18
Long story short 2 days after I was chasing my tire down the street and now for the past 2 days I've been driving like an old lady. Any advice on weather I should of re torqued them right away,which I just did after the fact and should I be worried again?
Old Apr 15, 2014 | 05:37 PM
nthinuf's Avatar
Most comments I have seen say to re-check at around 100 miles. But as you found out, it certainly doesn't hurt to check sooner. And as I found out, looking to see that all of your lugnuts were actually re-installed is a good thing too. (I drove away discount tire one time and found a few days later that none of the wheel locks were re-installed)
Old Apr 15, 2014 | 05:38 PM
BIGNICK's Avatar
Are you saying the tire literally came off your jeep and rolled away while your jeep became a tri wheel vehicle. Because then I would say some one forgot to tighten a tire
Old Apr 15, 2014 | 05:44 PM
bigred716's Avatar
Yes I'm saying tripod ride for about 25 feet.
They were all tight 2 days prior and once I put the forth back on the other rear tire was loose, the fronts were good.
Old Apr 15, 2014 | 07:26 PM
tjkamp's Avatar
That is scary!
You might check to see if the factory brake rotor retainer clips are still on the wheel studs. They should all be removed before installing after market rims, and if still preset can cause real issues. They really serve no purpose outside of the factory.
That's the only thing I could think of.
Good luck, hope this helps.
Keep us up to date. Curious to hear the solution.
Old Apr 15, 2014 | 07:31 PM
ronjenx's Avatar
Originally Posted by tjkamp
That is scary!
Old Apr 15, 2014 | 07:57 PM
tjkamp's Avatar
Originally Posted by ronjenx
Like he said, those things.
Thanks for the assist, ronjenx!
Old Apr 16, 2014 | 10:23 AM
bigred716's Avatar
Alright well those clips weren't on. I'm pretty sure it was just a freak accident lol. Probably gonna recheck them daily for a week tho don't need to ruin the jeep or hurt anyone.
Old Apr 16, 2014 | 10:38 AM
ronjenx's Avatar
How about the lug nuts? Are they matched to the holes in the wheels?
Old Apr 16, 2014 | 10:45 AM
Darth's Avatar
Default Fuels
Hi -
I too have fuels, and luckily have never experienced an issue like this (although this makes a great case to go get some hubcentric rings).
Mine have two different bolt patterns drilled into them... could it be possible that whoever installed them put them in the wrong pattern (they are only a fraction of an inch different, and may fit onto the studs, but not torque down correctly.
Just a thought.
