Full Traction 3" lift problem
Old Dec 31, 2008 | 10:30 AM
jktexas's Avatar
Default Full Traction 3" lift problem
Anyone have any suggestions on what I should do about a front coil spring that is bent backwards and rubbing the bump stop?
Old Dec 31, 2008 | 10:37 AM
Northridge4x4's Avatar
Sponsoring Vendor
Have you called FT?
David
Old Dec 31, 2008 | 12:10 PM
jktexas's Avatar
Yeah they asked me to email them pictures.
So I did, waited a couple weeks for a reply, then called them again and they asked me to send them the email again, so I did and I still haven't heard back from them. If anyone has some of these coils sitting around I would be glad to take one off their hands.
Old Dec 31, 2008 | 01:35 PM
Tjen97's Avatar
Your axle may not be centered; the arms may need pulled out and/or pushed in.
Old Dec 31, 2008 | 03:48 PM
jktexas's Avatar
Its just the one side. I know everything is centered so I know it's just that one coil spring.
Old Dec 31, 2008 | 09:31 PM
nangulator's Avatar
Question- did you loosen all of your control arms in the air(suspension hanging) and then re-tighten them on the ground after everything was installed? I ran into this with my right front coil spring because I forgot to loosen up the right front upper arm!
