full traction control arms
Old Oct 6, 2008 | 01:24 AM
Paolo's Avatar
Default full traction control arms
Hi,
this is one of my new full traction front lower control arms that i received from quadratec the last week:
How you can see, there are two holes; also the small hole appears to be a zerk grease point, but, in the box there are only two zerk fittings for the big center hole.
The questions are:
- what is this small hole?
- the control arm must be installed whit the zerk fittings up or down?
thank you to all
Old Oct 6, 2008 | 06:58 AM
txjeeplover's Avatar
I haven't touched the FT control arms personally, but I know it's rebuildable. The center hole is the zerk fitting. The outer hole should be where a retaining screw for the fully assembled joint goes to lock it all in place. But I defer to someone who has actually worked with these arms.
I always keep my zerk fittings faced inward towards the center of the Jeep so that I can get to all four by rotating back to front while underneath.
Old Oct 6, 2008 | 07:05 AM
Piginajeep's Avatar
center hole is the zerk,
they are rebuildable
Old Oct 6, 2008 | 07:56 AM
Paolo's Avatar
...thank you!!!
the second question was:
- the side with holes must go up towards the jeep or down towards the ground?
and, i must close with something the outer hole?
