Full Traction Front Sway bar link question
Old Jan 29, 2010 | 07:35 AM
JK CHARLIE's Avatar
Default Full Traction Front Sway bar link question
Hello everyone
I aleady install my new full traction long arm suspension, everything gone pretty good, but i have a question about the front sway bar links.
I install the front arms such as the manual says with the starting measurements, 24.5" front upper and 33.5" front lower, also the track bar 32.5", i double check it.
When i install the quick disconect sawy bar links i see that the distance between the links and the coils is diferent, been this distance larger on the passenger side than the driver side.
My question is, is this normal?, or do i have to make another adjustment or i made a mistake in the installation?.
Another question, what grease do you recomend me for the heim joints?
Hope you can help me.
Thank you!!.
This is a picture of the driver side, see the distance of the sway bar link and the coil:
This is the passenger side, the distance is bigger!!.
Old Jan 29, 2010 | 10:20 AM
Piginajeep's Avatar
Is the coils seated right? What's your pinion angle? It's not really that far off.
The heims do not need greased.
Old Jan 29, 2010 | 04:50 PM
JK CHARLIE's Avatar
the coils are seeting in the right pleace, i havent check the pinion angle, i will check it!!!!!.
Thank you so much, would you tellme what is the correct pinion angle that i should put.
Thanks!!.
Old Jan 29, 2010 | 05:44 PM
Piginajeep's Avatar
I would recommend that you set your caster angle at about +7°-8, if your can get it to that without causing driveline vibs.
it'll handle very well.
Old Jan 29, 2010 | 09:33 PM
warlord's Avatar
what about the ball joints? what grease would be good for them?
Old Jan 30, 2010 | 04:25 AM
Piginajeep's Avatar
I think u mean the spherical joint on the frame end right?
I use a red, high tac grease used on semi 5th wheels. It's heat and water proof. If u didn't pre-grease the bushings prior to install. I would pull the and grease, same thing with the track bars.
Old Feb 1, 2010 | 06:34 AM
Full-Traction Suspension's Avatar
Former Member
Default Full Traction Response.
Originally Posted by JK CHARLIE
Hello everyone
Thank you!!.
JKCHARLIE,
Chris (Piginajeep) was kind enough to draw my attention to this thread.
Can you please email me the pictures directly to me at the email address below (for some reason they are not visible to me on the forum).
Brendan V
Sales
Full Traction Suspension
brendanv@full-traction.com
661-398-9585
Old Feb 1, 2010 | 03:50 PM
Former Member
JK CHARLIE,
It does not appear there is anything wrong.
Pics from that angle suggest that there is just some natural bow in the coils in opposing directions.
If you are truly concerned, you should have it inspected by your alignment specialist or a professional installer.
Remember, a couple bucks in preventative work, beats every dollar spent on repair.
Brendan V
Sales
661-398-9585
Old Feb 1, 2010 | 05:40 PM
JK CHARLIE's Avatar
Default Tanks Brendan
Originally Posted by Full-Traction Suspension
JK CHARLIE,
Brendan V
Sales
661-398-9585
Brendan
Thank you for the advise!!!, i will take my JK to the shop to an exhaustive inspection!!. You are right there is a lot of money to take care of!.
Appreciate your time!!!.
Old Feb 2, 2010 | 08:38 AM
Former Member
JK CHARLIE,
If it turns out you need comprehensive trail testing.
Drop it off with me for 6-8 months and I will thoroughly test it at Moab, KOH, TDS and the 'Con.
Anything I can do to help. :0)
Brendan
