Full traction front trackbar bracket?
Put on my 2.5" TF coil.
Front axle is shifted .5" to the drivers side.
Rides fine. No pulls, wobbles, bumpsteer....
Just found a full traction front track bar bracket I had laying around from a 2" spacer kit.
Here's the ?....
Should I put it on?
Here's the ?....
Should I put it on?
The "correct" thing to do would be to use a TF adjustable track bar to correct the axle position.
I would suggest not starting a Frankelift. The FT bracket was designed for exactly 2" of lift, while the 2.5 TF coil lift usually provides 3"+. If you develop suspension or steering problems that bracket will be in question.
