Full Traction tracbar squeek?
Is anyone else experiencing squeeks on their (in my case) front trackbar? It's driving me nuts. I'm using Amsoil Synth Grease on all my zerks, but as you know, the trackbar can't be greased. I'm thinking of taking it apart, then drilling & tapping the joint. Anyone else done this? Does is finally solve the sqeeks?
js.
js.
js.
js.
Its been greesed 3 times in two years, Its never needed it, I just greese everything often.....
Some guys do tap and install a zerk, IMO its not needed but some do.
I drilled and tapped mine. It was fairly easy to do, it took about 5 minutes to add the zerk. Honestly though, Im not sure if I really needed to.
I used green grease and its been quiet for about 9 months.
I'm wondering if I even need to remove the trackbar... Maybe just scoot under there with a drill... :-)
js.
what piginajeep and bly109 said. if you use the right kind of grease when assembling the bushings, you will not get any squeaks. i am still running an adjustable FT front track bar now and it does not squeak at all.
js.
js.
I've tried white lithium grease, axle grease and mobil 1 synthetic axle grease. None seem any better than the other. Honestly, I think the problem is that the weld on the bar was not grinded down enough. The weld appears to compress the bushing in slightly where it makes contact. I'm still waiting to hear back from FT regarding this issue.
Thanks,
js.
