Full Traction Track Bar Bracket
Old Apr 29, 2009 | 08:48 AM
eDiveBuddy's Avatar
Default Full Traction Track Bar Bracket
Need some help figuring out these instruction. Maybe I've been looking at it too long, but I can nt figure this out without having extra hardware.
Hardware list.
1 ) Spacer 1.4 X 0.56 X 1
1 ) 1/2" X 1" Bolt
1 ) 1/2" X 1.5" Bolt
1 ) 1/2" Metal Lock Nut
3 ) 1/2" Flat Washers
1 ) 1/2" Lock Washer
1) 9/16" X 3" Bolt
2) 9/16" X 3" Flat Washers
1 ) 9/16" Metal Lock Nut
Instructions
To install, remove factory bolts from frame. Install using
OEM bolt, nut and washer and torque to 80lbs/ft. Use
the 1.56 Long spacer on the center bolt. Install the 9/16”
x 3” bolt to secure the track bar
That's it for the instructions.
This illustrates my question.
It also illustrates my problem.
I have 2 bolts and one hole left????
Old Apr 29, 2009 | 09:15 AM
Robar's Avatar
There is also one small bolt that goes towards the top of the bracket on the inside of the frame just above track bar.
Old Apr 29, 2009 | 09:37 AM
eDiveBuddy's Avatar
Thanks a bunch. Am I to assume that they both take nuts? I don't have a 1/2" lock washer, but I have an extra 1/2" lock nut. As soon as I went and looked at it all I could say was Duh!
