Full traction ultimate came today
Northridge 4x4,
I have the black diamond 3" lift and it rides very rough. It is very stilff. If you were going to upgrade to a better lift which of these would you pick and why or why not? This jeep is used for 99% on road, so I am looking for a very good ride quality...
I am thinking about getting the Superlift Superide Select (SS) Monotube Shock Absorbers by Bilstein to go along with my next lift. If you think there is a better shock to get for the money let me know. Thanks in advance...
I'd be willing to bet you either:
1) Have too much air in your tires.
2) The tires you have just don't ride very well. Tires can have a HUGE impact on how any vehicle rides/drives. Simply changing to a different tire in the same size can make a night and day difference sometimes.
You need to be running about 25-27psi in the front tires, probably 24-26 in the rear tires. Try that, and if it doesn't ride like it should, put your stock tires/wheels back on (making sure you have the stock air pressure in them) and see if it's better.
Does anybody have the exact length and diameter of the regular Ft springs so I can measure my HD springs. Then there will be A definite way to tell the difference if any body else has questions.
