G2 core 44
Old Sep 20, 2014 | 04:14 PM
JE8154's Avatar
Originally Posted by nthinuf
Haven't looked at the differences in the brackets/C's between dyna/tera/g2, but they have different tube specs.
Stock
Outer Diameter - 2.5"
Wall Thickness - 1/4" (.25)
PR44
Outer Diameter - 3.0"
Wall Thickness - 5/16" (.3125)
PR44-Unlimited
Wall Thickness - 1/2" (.50)
Tera 30/44
Outer Diameter - 3.25"
G2
Outer Diameter - 3.00"
The G2 housing seems to be the weakest of the three aftermarket housings, but still a bit stronger than an un-modified stock housing.
A discussion on the comparison between a gusseted/sleeved/trussed stock housing to any of these is way beyond me, but I assume the end forgings on a PR are stronger than a gusseted stock C, and a 3.0" x 1/2" tube is stronger overall than an 'inner sleeved' stock tube just based on seeing posts here about sleeved stock housings shattering or bending.
G2 has conflicting info even on their own website and list the tubes at 3"x1/4" and 3"x5/16. Teraflex has the option of 1/2" tubes as well.
Old Sep 20, 2014 | 04:30 PM
nthinuf's Avatar
Hadn't heard about the 1/2" tube option for TF housings, good info to add.
I noticed the conflicting G2 info as well, so just went with the specs on their site. Quadratec actually lists two completely opposite specs on the same page:
The CORE 44 includes heavy duty forged inner C ends, and 3" x .250" wall tubing to resist bending in even the most extreme conditions. All CORE 44 brackets are laser cut and CNC formed from 3/8" steel for added strength, and are designed to allow bolt-in installation.
Product Details
Heavy-duty 1/4” laser cut brackets
Heavy duty 3” diameter 5/16” DOM tubes
