Gauges?
Old Nov 19, 2008 | 02:44 PM
ricrac12525's Avatar
Default Gauges?
Has anyone installed oil pressure/water temp gauges? What brand, and where did you mount them? Thanx
Old Nov 21, 2008 | 04:14 PM
Default bump
Bueller? Anyone?
Old Nov 21, 2008 | 04:42 PM
donjonald's Avatar
weird, i was just thinking the same thing.
i remember seeing some digital gauge a long time ago...
or am i just dreaming
Old Nov 21, 2008 | 06:19 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
I have two gauges mounted on the pilar! Autometer voltage and Transmission temp mounted with cup mounts. I have pics at home but at this moment I am MOBI.
Old Nov 21, 2008 | 09:22 PM
JK07's Avatar
I have installed 3 Gauges Volt/Oil Pressure/Oil Temperature check the Electronics section few people have installed differnt gauges on different places
mine
https://www.jk-forum.com/forums/show...ghlight=gauges
Old Nov 22, 2008 | 05:03 PM
Windrocker's Avatar
Aeroforce is the only way to go ....
Old Nov 22, 2008 | 05:22 PM
metalcd's Avatar
whats the deal with that aeroforce gauge can you change what it shows you?
Old Nov 22, 2008 | 05:27 PM
Hammer Down's Avatar
Default Wow
That is f'n cool Tell us more....
Old Nov 23, 2008 | 08:12 AM
Windrocker's Avatar
The Aeroforce simply plugs into your OBII port and gives you read outs on more things than you can ever want. Amazingly simple to install and it would take a dash full of "regular" gauges to read everything it does.
You have a couple of different ways to to view the information. The small button on the left is used to scroll through the different sensors to display whatever you want on the top portion of the gauge. The button on the right does the same for the bottom portion of the gauge.
You can also select your 8 favorite readouts and have the gauge scroll through them continuously.
You can find all of the details on the Aeroforce here ..... http://www.aeroforcetech.com/
Old Nov 23, 2008 | 04:59 PM
AZJeeper's Avatar
Community Favorite
What mount did you use?
