gear durability compromise
I've been reading some of the posts on 5.13's breaking. That makes me a little nervous since I'm not a diy axle guy, am on a budget, and the Jeep IS my daily driver. Now, knowing that the lower the gear the smaller the pinion, hence, weaker gear set; what would I be gaining/losing by going to a 4.56 or 4.88 ratio? I know the RPMs are not really an issue since they don't vary much between the sets.
60MPH
1621RPM stock
1812RPM w/35's and 4.56's
1940RPM w/35's and 4.88's
2039RPM w/35's and 5.13's
My big question is, what do you gear guys/gals recommend for a RELIABLE, DURABLE ratio that will see 90% street duty?
60MPH
1621RPM stock
Ok..makes complete sense! My jeep will never see elevations and rarely even go above sea level hahaha...I was just wondering b/c I've read that any automatic should do 5.13 and manual should do 4.88..and I also read somewhere that 5.13s are not made for interstate speeds and that they could have complications and/or break at 70 to 75...is all that right??
Keep in mind I'm in Colorado at 4500 ft and have a fairly heavy 4 dr. The only downside I see to 5.13's is that if you go with 37's you'll wish you had 5.38's!
