Gear install break in period
Old Jun 18, 2009 | 05:39 AM
Offroadme's Avatar
Originally Posted by snopro
You MUST!!!! give your gears a break in period. If not im going to laugh at you when your back on here because you just wasted a ton of money doing a gear install and you just shattered them. Ive seen it happen in rams probally 100 times. I'll put gears in for a few people as a side job and they come back screamin and yelling because they went balls to they walls and messed them up. I changed my gears in my ram 4x4 with 4:56 gears about 3 years ago and no problems at all. I just dont want to see you waste a ton of money because you dont want to break them in
well im not saying i don't want to break them in im going to take it easy im just concerned about the long trip in july. i don't know if im going to drive the jeep 500 miles before july 18th. and i just wanted some solid advice about what to do before the trip to ensure i won't have a problem being so far from home.
Old Jun 18, 2009 | 04:08 PM
mkjeep's Avatar
I wasn't saying the op shouldn't break em in. Just lookin for the answers. Me, I drove mine like I stole it.
Old Jun 18, 2009 | 04:16 PM
NGINIER's Avatar
I had a similar issue with a trip interfering with the break in period. I eventually had to just drive 20 miles out somewhere, wait for 90 minutes or so and drive back everyday for a while. It felt like a lot of wasted time but I had the long trip and I didn't want to get them that hot for that long.
Old Jun 18, 2009 | 07:53 PM
ronjenx's Avatar
Proper break-in will not cause damage.
Not breaking them in may cause damage.
Given those two choices, why would one not perform a proper break-in?
Old Jun 18, 2009 | 08:49 PM
jawsk2's Avatar
So, changing the oil after 500 miles is pretty standard?
Old Jun 18, 2009 | 08:53 PM
beadbus's Avatar
Originally Posted by mkjeep
I don't understand new gears being "broken in". Did you stop every 15 miles to check your gears on your new jk after you bought it from the dealer or any other vehicle for that matter? Either they're set-up right or not, maybe that's the reason for stopping. Maybe it's a liability or warranty reason from aftermarket gear manufacturers, cause they all say it. But those certain gears shouldn't be any different from a stock vehicle straight from the factory with a couple miles on them. Can anyone give a logical reason of why aftermarket gears should be babied vs the stock gears.
MK Jeep, Here is the answer to you statement....
When you purchase a NEW car, (i.e. Jeep, they contract for axles that have been tested and PRE-broken in) This means that the gears have already been tested and broken-in prior to the sale of the vehicle. This is known as LAPPING to match the parts. Then the manufactures flushes out the fluid to remove all the metal powder that mixes with the gear oils.
Don't believe that the aftermarket gears are SOFTER......
When you buy aftermarket gears, this break-in process HAS NOT BEEN PERFORMED and that is why the installing and break-in period is SO IMPORTANT. Yes you want to heat up the gears, let them cool down and repeat this 4-5 times. This allows the hot gears to expand and contract when cooling and properly mesh together for trouble free years of enjoyment.
I just had my gear oils changed today after 500 miles and you could clearly see the black power like streaks in the oil when you put it on your fingers. I am glad you asked as I found this very interesting. Hope this helps...
Old Jun 18, 2009 | 09:05 PM
mkjeep's Avatar
I have now seen the light, finally a complete answer. Thanks!
Now I don't know what to do with my life the riddle has been solved. I knew if I kept it up though someone had to know and not just say because your supposed to.
Old Jun 18, 2009 | 10:11 PM
bigbluejk's Avatar
lmao. MK, don;t go jump off a bridge because no more mysteries exist in your life. Only reason I ever break mine in is because that is what I have always been told to do. I always run Dino oil for the first 500 doing the whole short trip cool down stuff, then switch to sythetic and rolling how I want. Worked so far. I have no reason for what I do, just what I have done in the past.
Old Sep 19, 2009 | 04:18 AM
kflash's Avatar
Older post revisited. The shop that installed my 5.13s only works on Jeeps. They filled my diffs with royal purple and said to take it easy for the first 500, but also said there is no need to inspect at 500 (agreed that there are lots of opinions on this, but that was his stance). This shop is maned by Chrysler techs that mod jeeps in the evenings/Saturdays.
Old Sep 19, 2009 | 04:35 AM
JPop's Avatar
Here's a shot of a magnetic drain plug and 600 miles of normal wear on a new set of gears. (stupidface's JK) If you want that floating around in your differential, don't change your gear oil.
