gear oil level
Old Jun 5, 2011 | 12:44 PM
codymac08's Avatar
Default gear oil level
I changed my front and rear diff oil today after putting about 500 miles on my 5.13 gears and the rear only held a little under 2 quarts and the front held 1 quart. Is the normal because of the added size in R&P. Im heading to the beach in the am and want to be sure its right.
Thanks.
Also 4wd high or low for driving on the beach??
Old Jun 5, 2011 | 12:56 PM
internski's Avatar
What axles are you running? Do you have stock diff guards?
Old Jun 5, 2011 | 12:58 PM
joe002's Avatar
In my Rubicon diffs, Riddler covers, 5.38s I put 1.375q in the front, and 2.5q in the rear.
I don't drive in the sand, but in any case turn O/D off.
Old Jun 5, 2011 | 01:10 PM
codymac08's Avatar
Guess I should have included that stuff. 2007 jku x w/ stock axles and stock covers. I put oil in til it ozzed out and then put in the plug back in.
Old Jun 5, 2011 | 01:15 PM
Goeagles88's Avatar
It sounds like you're fine. I did the same thing except I have an ARB rear cover. The rear 44 holds the whole amount because of how you put the fluid in the ARB, but the stock 30 cover only allowed 1 quart. According to the MANY posts I read since yesterday on the subject, that's normal and okay as long as the fluid oozes out of the fill hole. I may go ahead and pony up for the ARB front cover just so it's easier to fill. The stock cover is a beyotch...
Old Jun 5, 2011 | 02:08 PM
Rockroaster's Avatar
Did mine lsat month as well, and used the same amount as you op. You'll be fine.
Old Jun 5, 2011 | 02:11 PM
codymac08's Avatar
thanks everyone for the quick info. i just didnt want to burn up those new gears
Old Jun 5, 2011 | 02:14 PM
Croce's Avatar
Gear oil should be at level shown in Pic. You can either use a Zip tie to measure, or i just stick my pinky finger in there (riddler cover) and see if i can touch the oil
You also dont want to overfill because i heard it could cause damage to the axle seals- Someone correct me if im wrong, but i believe that happened to someone on here
As for sand, what i've read is 4LO so ESP is disabled and O/D off. If you plan on going faster than 20mph or so. Use 4H but disable ESP manually.
