Gear patterns
Old Feb 15, 2016 | 03:58 AM
PsychoCupcake's Avatar
Originally Posted by Chuck-The-Ripper
The contact was centered perfectly within the tooth, the only problem was that instead of it leaving a wide distinguished mark like everything shows, it was only a thin line.
Right, which is why we suggested putting more pressure on the pinion when you turn the ring gear to get the pattern so that the teeth create more of a contact. Then you get a clearer picture instead of just the thin line. Can you redo the pattern with more pressure/tension on the pinion and then repost some pictures?
Old Feb 15, 2016 | 04:52 AM
Chuck-The-Ripper's Avatar
Yes I can do that! I thought that may have been the issue but I wasn't 100% sure. Thanks!
Old Feb 15, 2016 | 07:27 PM
jtphoto JK's Avatar
Now here's that sharp inner line on the pattern you are getting.
Old Feb 15, 2016 | 07:28 PM
jtphoto JK's Avatar
And this is what you should be getting. Is it possible the carrier shims got mixed up left and right side?
Old Feb 17, 2016 | 06:59 PM
I started with a "blank" housing, so I had no shims to start out with. I see now that sharp line, thanks for the picture! Would you suggest pulling some shims from the pinion?
Old Feb 17, 2016 | 07:40 PM
jtphoto JK's Avatar
As it stands you first need to shift some shims from one side of the carrier to the other to get the pinion back out of the ring gear a bit. Then check the backlash again. The amount of backlash will tell you whether or not you need to remove shims from the pinion.
Old Feb 18, 2016 | 01:14 PM
Readjusted shims. .005 backlash this is the pattern.. Any thoughts
ID:	638121   Click image for larger version
ID:	638122   Click image for larger version
Old Feb 18, 2016 | 01:45 PM
Looks reasonable to me.
Old Feb 18, 2016 | 04:21 PM
jtphoto JK's Avatar
That's better. Good job.
Old Feb 18, 2016 | 08:36 PM
Sweet. Thanks! Any insight on the rear?
ID:	638171   Click image for larger version
