Gear patterns
Old Feb 19, 2016 | 06:39 PM
  #21
jtphoto JK's Avatar
Originally Posted by Chuck-The-Ripper
Sweet. Thanks! Any insight on the rear?
More info please.
Fresh instal or original carrier with original shims. ?..
Is that a lock right in the original carrier?
Old Feb 19, 2016 | 10:36 PM
  #22
Chuck-The-Ripper's Avatar
Here's actually the best pattern I've gotten on the rear. Original carrier with an Aussie locker. New 4.88s with all new bearings.
ID:	638253   Click image for larger version
Old Feb 20, 2016 | 05:25 AM
  #23
jtphoto JK's Avatar
There yah go. Nice.
Old Feb 20, 2016 | 11:10 AM
  #24
Now I just need to get this damn crush sleeve crushed... Lol
Old Feb 20, 2016 | 01:10 PM
  #25
jtphoto JK's Avatar
Oh that is another story. We built a plate with bolt holes and a center hole to match the flange. We welded that to a long pipe for leverage. Then wedge that pipe to the frame or floor. Then a 3/4 drive socket, ratchet and loooong pipe on the pinion nut. The alternative is a high torque impact. Once it starts to snug up, check often with the torque wrench. It doesn't take much to go too far.
Old Feb 20, 2016 | 09:47 PM
  #26
I have an Adams driveshaft in the rear, so I ended up taking a pipe wrench and putting it on the yoke where it's kind of box shaped, and putting a floor jack against it. Worked pretty well but it was a pain in the ass. Couldn't find a 1 5/16 socket anywhere so I used a dremel to shave a bit from the inside of the yoke and the outside of a 36mm socket to fit. Got it all done and took it for a spin. Everything felt fine and drove nicely. I added an Aussie locker back there at the same time. It's extremely loud. The jeep kind of felt like it had a lot of backlash if that makes sense but I'm pretty sure it was the locker. Hard to distinguish between what's normal for that and abnormal for the gears. I guess I'll find out at 500 miles how good of a job I did... Hopefully I don't find out sooner, lol. Thanks for the help though
, I really appreciate it.
Old Feb 21, 2016 | 06:22 AM
  #27
jtphoto JK's Avatar
Awesome. No problem, Glad you got it all done.
