Gear ratio question
Old Feb 9, 2014 | 08:06 AM
ronixwrangler's Avatar
Default Gear ratio question
This might sound a little like really? But I was wondering how can I tell what gear ratio I have? I have a 2011 Sahara 2 door. Thanks guys
Old Feb 9, 2014 | 08:10 AM
Bonedoc's Avatar
There are threads that tell you how to use your vin and get your JK build sheet. Look at your rear diff, should be a tag on it. You could always jack up your rear axle and pin your rear drive shaft and count how many rotation you get for one rotation of your rear axle.
Old Feb 9, 2014 | 08:17 AM
I'll def check into that, thanks!
Old Feb 9, 2014 | 08:23 AM
ronjenx's Avatar
There doesn't seem to be a tag on the JK axles.
Jack one front tire off the ground.
Spin it by hand 2 complete revolutions while counting the drive shaft turns.
The number of drive shaft turns will be your gear ratio. Count carefully because there isn't much difference between the ratios.
A chalk mark on the tire and drive shaft will make counting easier.
Old Feb 9, 2014 | 08:30 AM
Originally Posted by ronjenx
There doesn't seem to be a tag on the JK axles. Jack one front tire off the ground. Spin it by hand 2 complete revolutions while counting the drive shaft turns. The number of drive shaft turns will be your gear ratio. Count carefully because there isn't much difference between the ratios. A chalk mark on the tire and drive shaft will make counting easier.
Great, thanks!
Old May 14, 2014 | 06:25 AM
Swampduck's Avatar
If you don't have the Spec Sheet or bought your JK used like I did you can find what your specific JK shipped with here
Jeep - Contact Us
Navigate on the left side and choose equipment listing then just put in your vin
