gears
Old Jul 25, 2009 | 10:34 AM
bwink999's Avatar
Question gears
ok i have a 2.5 lift that im gonna swap out for a 4" and put 35"s on. now what kinda gears do i need and am i gonna need new sway bars or anythings like that.
Old Jul 25, 2009 | 10:46 AM
DESERT RAT's Avatar
5.13's without a doubt, what else you will need depends on which lift you get, and how complete it is. A 4" lift will need track bars, control arms, swaybar links, drive shafts.
Old Jul 25, 2009 | 11:04 AM
bwink999's Avatar
basiclly i just wanna run 35s and have it look and function great i dont go out alot with it but if i do i want it to hold up
Old Jul 25, 2009 | 11:11 AM
DESERT RAT's Avatar
Then you should probably go 2.5" coil spacer lift and a 1" body lift. This will clear 35"s and not get too expensive !!
Old Jul 25, 2009 | 11:15 AM
seer1's Avatar
Auto or manual tranny?
Old Jul 25, 2009 | 11:17 AM
bwink999's Avatar
thats what i was thinking and its an auto but if i do the spacer would i need to do the sway bar and all that
Old Jul 25, 2009 | 11:43 AM
JPop's Avatar
There was a write up earlier this month on an inexpensive kit that will get you where you want to go. Budget minded without regrets as what I would refer to it as.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Jul 25, 2009 | 12:26 PM
ZoSo-Green's Avatar
As far as gearing goes, w/ a 6 speed its whatever you can live with.
But an auto is a 4.88 minimum!!! 5.13's are ideal w/ 35's.
... But the manual should have at least a 4.10.
