gears and carrier question
Old Jun 7, 2015 | 05:23 PM
neal90's Avatar
Default gears and carrier question
In the next few month I am going to regear my jk. It has the factory 3.21 gears in it (boo) and I'm wanting to go with 5.13. I have read and understand that the carrier for the front dana 30 will need to be caged to except the bigger ring gear. That i understand. But what about the planetary gears will I need new ones for the bigger carrier, and also the front axle has an auto locker in it right now will it be trash.. I also plan to put sleeves in to help out, But with 35 and a dana 30 should i just put the planetary gears back in or keep the locker if I can. Thanks for the help. Also the rear is a dana 44 (with 3.21 obviously ) will that carrier need to be replaced also??
Old Jun 7, 2015 | 09:40 PM
sa29560's Avatar
Yes both carriers, do a locker too. Good luck
Old Jun 8, 2015 | 12:30 AM
nthinuf's Avatar
Which locker is in the front housing? I assume it is a lunchbox type locker (aussie) that will go in the open carrier? If it is a full case locker (detroit), it is the carrier. Either way you will need a new carrier -or- a new full case locker. By planetary gears, you mean the spiders? I think they are the same regardless of carrier/ratio (assuming an open carrier). But, you have a locker. Weren't the spiders replaced by that locker?
The rear carrier is the same for all JK gear ratio's. (while the axle is torn apart for gears is a good time to go ahead and install traction, so you might at least consider a few options)
Locker or no locker - personal preference/judgement call/luck/flip a coin...
A pair of truetracs is a relatively popular route, and very cost effective when compared to some of the other options. Worth looking at, at least.
Old Jul 29, 2015 | 09:12 AM
AussieLocker's Avatar
You can reinstall your auto locker into your new front carrier. The ID of carriers are the same, no matter the gear ratio.
Old Jul 29, 2015 | 03:03 PM
Northridge4x4's Avatar
Sponsoring Vendor
You will need the carrier for sure for the front. The spiders/side gears if you don't put an Aussie locker in. The rear does not change as both the Rubicon and Non-Rubicon use the same thick ring gear.
-Tim
