General Grabber at2 MEASURED sizes??
Old Sep 9, 2014 | 03:59 PM
tatrhed's Avatar
Default General Grabber at2 MEASURED sizes??
I really like the general grabber at2's but can find anyone running them that has listed the actual size once mounted on the jeep. Can anyone help?
Im looking for 285/75/16, 295/75/16, 285/75/17 and 315/70/17.
Old Sep 11, 2014 | 06:02 AM
tatrhed's Avatar
Almost 100 views and no one knows anything about these things?
Old Sep 11, 2014 | 01:39 PM
Strider's Avatar
305 70 16 mounted on 16X8 rims 32 in exactly. These tires have about 1000 miles on them.
Old Sep 11, 2014 | 01:50 PM
htm7765's Avatar
I have them on 17 inch rims not 100% sure the size I ended up with but if you go to tire rack you can search that tire in available sizes and the give you the overall size I believe mine was 32.7 inches I will check the size when I get a chance
Btw love the tire !!!
Old Sep 11, 2014 | 03:43 PM
nthinuf's Avatar
He is looking for measured size, since that can be different (sometimes much smaller) than the size listed in the specs.
I know this is a different tire in a different size, but as an example -
the spec on my current RockyMountains is 36.3" x 13.1". Plugging the 325/80/16 into an online calculator gives 36.50" x 12.8". And very un-scientifically, just using a tape measure and a board across the top, I measured the spare at 36.50", and a front tire (at 28psi under normal vehicle load) at 35.50". So they seem to be fairly true to size, and I lose about an inch from vehicle weight. (btw, 35.5 is what I put in the programmer, and the speedo matches gps.)
Old Sep 11, 2014 | 05:03 PM
Strider's Avatar
On general tires web site they list the specs for 305 70 16 grabber at2 as being 32.8 in dia. when the actual measurement is exactly 32 in. @ 35 lbs. measured with a straight edge across the top of the tire to the concrete.
Old Sep 22, 2014 | 11:18 AM
tatrhed's Avatar
Thanks for the responses. Yes I was looking for measured values as I have heard some tires as much as 1.5in shorter than manufacture "spec." I know in the grand scheme (for my application) that .5" is going to amount to nothing, just curious about this particular tire because it is the one I cant find much real world info on.
