Gerry Can mount
Old Apr 22, 2010 | 11:37 AM
rynokid's Avatar
Default Gerry Can mount
I have a Smittybilt SRC rear bumper with swing away tire carrier. anyone have suggestions on where to mount a single gerry can?
Name:	pa pics etc 013..jpg
Old Apr 22, 2010 | 11:43 AM
sm_rubi's Avatar
Attachment 62448
You can buy the Rockhard tank mount for the left side, it fits without any problems. I'll post up pics of ours. Their trail rack works as well with a little modification (sectioned to lower the mounting height) and you can run the right tank mount as well. One thing of note is that the right tank mount has a gap due to the way the tire mount is not centered by design. I'll look for better pics but here are a couple to give you an idea of what you can do...
This pic shows the gap as a by-product of the SB tire mount being off center. It really does allow you to mount something in the gap so I see it as a positive.
Old Apr 22, 2010 | 11:46 AM
rynokid's Avatar
Thanks SM. I cant mount a can on the right because i welded a post to it so i can mount my hilift to it. ill have to take a pic of it because its a pretty good mod!
Old Apr 22, 2010 | 11:47 AM
Tgoods 09 X's Avatar
Heres a pretty good write up!
https://www.jk-forum.com/forums/show...-on-Spare-Tire
Mounts to the spare tire and looks pretty good!
Old Apr 22, 2010 | 01:19 PM
Mark Doiron's Avatar
Originally Posted by ECHO
Also seen someone who had it on the Spare Tire
Yep, though you might have to modify a little if you've moved your license plate:
Jerry Can Mounted on Spare Tire Thread
Old Apr 22, 2010 | 03:52 PM
michdave's Avatar
check out Rotopax fuel cells!
rotopax.com
they're thin and easy to mount. They sell mounting brackets that look like they could bolt on pretty easy. Whne I'm ready, i thnk thats the route I'm going.
Last edited by sm_rubi; Apr 22, 2010 at 05:48 PM. Reason: No non-sponsor clickable links.
