Getting Code P0159 when running 91 Superchip any one else ?
I being testing the Superchip at different settings.
Now using 93 Octane and running the 91 performance my check engine light comes on and the code I get is P0159 (O2 Sensor 2/2 Slow response). I cleared the code and it comes up again but when I change to 87 performance the code does Not comes up.
Has any else run into this situation ?
Thanks.
Thanks.
Have you gone online and updated your Superchip tuner? The service bulltetin that came out recently was to address the O2 sensor issue, I would suggest that the Jeep software and the Superchip software both need to be updated to insure they are compatible.
The jeep had the reflash/reprogram for a recall related to the O2 slow response a Year ago.
I had the Superchips after that and no problem even run it at 91 set up and no problems.
I did post it in the Superchips Forum Trouble section but no reply. We will see.
The code only happens when running the Tuner at 91. I set it to 87 Performance and no problem/ no code.
Even after running for over 100 Miles in the highway.
