Getting swaybar out of the way...?
Old Nov 21, 2012 | 09:34 AM
hbar97's Avatar
Default Getting swaybar out of the way...?
Hey JK forum,
Im pretty new to wheeling and I disconnected the swaybars for the first time a few weeks ago. I have a 3 inch BDS lift so i have the Front Ultimate Swaybar Disconnects that came with kit. Disconnecting the front left side went smooth and i was able to secure the swaybar up and out of the way no problem. When I got to the right side i ran into a problem. When i try to swing the swaybar forward up and out of the way, what i think is the steering stabilizer is blocking the swaybar from swinging away. I dont know if its the steering stabilizer for sure but i think it is. I'm just wondering how can i get the disconnected swaybar to swing past the steering stabilizer so its out of the way when wheeling?
Here are some pics of the problem
Old Nov 21, 2012 | 09:50 AM
Jk_Dean's Avatar
Ok I like simple problems. When you disconnect the links just rotate the away bar up a little before hooking up either side. Works for me.
Old Nov 21, 2012 | 10:16 AM
Monte417's Avatar
That is your tie rod blocking it not your stabilizer
edit: meant drag link sorry
Old Nov 21, 2012 | 10:45 AM
Jk_Dean's Avatar
Lol sway bar not away bar.
Old Nov 21, 2012 | 10:54 AM
k0260's Avatar
x2 right, disconnect both sides before securing either. This will give you plenty of play to easily remove links.
Old Nov 21, 2012 | 05:29 PM
hbar97's Avatar
Awesome thanks guys.
