Going from pucks to springs....
Guys...simple question...if I want to go from a mopar 2" pick lift to a spring lift of 2.5"....do I need to complete removal of the puck lift to move to the spring lift or can I use some of puck lift parts?
What was actually included with your puck lift? Just pucks? Did it come with longer drop links? Longer shocks? Bump stops? Track Bar mounts? Brake line brackets or longer brake lines?
If it doesn't have some of these components you may want to just get a complete kit if you have enough components to work with then you might be able to do just the springs. As mentioned above Rock Krawler has an excellent lift and we can help work with your budget. PM us if you would like to discuss in detail and would like any quotes.
Good luck with the build!!
