Goodyear Duratrac?
With your stock wheels, probably 33" w/o rubbing when you turn. Others on here fit 35" tires with no lift, but they have spacers or wheels with <= 4.5" backspacing.
With only 2" of lift 33s would fit no problem. If you want to move up to 35s they will rub if you go off road and disconnect the sway bars. Flat fenders or a 1" body lift would give you enough room for 35s.
