Gorilla Lug Nuts
I've been using these but it's only been about 4 months. The coating is supposed to be solid on these...
Amazon.com: DPAccessories D5242P-2308/23 23 Premium Black 6 Spline Drive/Tuner Wheel/Lug Nuts (1/2"-20) 1.35" Tall: Automotive
Only problem with using a regular patterned spline lug nut is that they can still be removed with a 16mm/17mm socket
So to address that I also use a set of these as my "locking" lug nut...
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
You really can't avoid corrosion on the lug nuts. Once the surface coating is damaged, it's an invitation for rust. That said, there are certain processes that do a great job of preventing rust (e.g. Zinc chromate). Most aftermarket lug nuts are not likely to be treated with such processes.
Lug nuts are cheap. Buy a new box in the Spring if it bothers you.
I've been eyeballing the Dorman Lugs.. We'll be getting rid of the factory shielded version soon..
711-205A
711-211
Source: Dorman Products - Search Results
My black ones looked like shit 6 months after... If you rotate your wheels frequently it will occur quicker as well.
This place sells them individually
http://www.brandsport.com/grla-21188bc.html
May end up looking for some different ones if these start to rust.
Gorilla Automotive Products - Lug Nuts, Wheel Locks, Auto Security, Wheel Accessories
these are what I run. No rust and hard one piece cast lug so no soft tin cover that goes to crap like stock.
on my black ones.
