got alignment still pulls left bad please help ideas
Old May 20, 2010 | 03:35 PM
mattymat04's Avatar
Default got alignment still pulls left bad please help ideas
ok threw on 2.5" teraflex lift and other goodies yesterday. Went got alignment now its 100 times better but still pulls left. I have adj trackbars front & rear. I tryed to get these as good as I could. I noticed they didnt touch these could this be my problem? maybe one axle is off or what else could cause this? just some info also have stock control arms
front left
camber -0.9
caster 2.6
toe 0.11
sai 13.1
included angle 12.2
front right
camber -0.4
caster 2.7
toe 0.11
sai 12.6
included angle 12.2
front
cross camber -1.4
cross caster -0.1
cross sai 0.4
total toe 0.21
rear left
camber -0.6
toe 0.14
rear right
camber -0.4
toe 0.18
rear
cross camber -0.2
total toe 0.32
thrust angle -0.02
Old May 20, 2010 | 04:03 PM
wazooz2424's Avatar
check out the writeups and perhaps adjust your tow. could also be a bad tire on the left pulling you, crown in the road, axles not centered right.
Old May 20, 2010 | 04:25 PM
JK-Tex's Avatar
That caster seems way light.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old May 20, 2010 | 04:30 PM
wazooz2424's Avatar
You're right. Didn't even notice. Should be closer to 4-5degrees. Nothing you can do without CAs though. With a BB you shouldn't really need CAs.
Old May 20, 2010 | 04:31 PM
subdude732's Avatar
i go with a bad tire!...might need rebalancing!
Old May 20, 2010 | 04:42 PM
mattymat04's Avatar
its a coil lift drove straight before new coils. just was a super hard ride had a 2"spacer lift. Now the ride is super smooth but the damn thing wants to switch lanes right away. There are no vibrations. tires look fine. Ill bring it back tomorrow i just wanted to maybe get some insite cause i dont know all the terminology at all. Thanks for all the replies so far
Old May 20, 2010 | 05:29 PM
wazooz2424's Avatar
I'd your tires aren't directional, put the left on the right and the right on the left and drive the same roads.
Old May 21, 2010 | 11:54 AM
mattymat04's Avatar
oh well still the same. I found a guy who I should have just brought it too in the first place that sais he can get it right. Said throw in your adj control arms then bring it back. Im still waiting for the lowers probably next weekend ill throw them in. So much fun
Old May 21, 2010 | 01:22 PM
RevyJKU08's Avatar
I say it's your caster that's affecting your pull. You should be more like +4.2 to 5.0 for caster. Is this a TF coil lift? If so you will need some Adj Front Lower control arms as these lifts typically give you over +3" of lift.
Old May 21, 2010 | 05:35 PM
mattymat04's Avatar
bought all 8 control arms and front and rear driveshafts this better do it. Jeep is nice to look at but hell to drive at the moment. <<<< hates this love to drive my jeep. I hope to have all the stuff by next weekend ill get the control arms on. Then have the guy I found throw on the driveshafts (might be out of my realm) and adjust everyhting he seemed pretty confident that he could fix this
