Got my lift in..but
Old Jul 23, 2009 | 09:03 PM
Spetz's Avatar
Default Got my lift in..but
FINALLY got my RC 4" lift, spacers and disco's in tonight but have a question. When installing the lift kit, should I put in the new cam pins, or leave the stockers in place. If I leave the originals in, I don't have to cut out the hole for the new ones, but I'm not sure if I can get enough angle out of the stock ones. Any ideas or suggestions ? This is going on an 08 4dr Sahara.
Old Jul 23, 2009 | 10:03 PM
nthinuf's Avatar
Do a quick search on Cam Bolts before you install them. You'll come across a ton of negative feedback regarding those bolts, so do yourself a favor and hold off a bit until you get more info on the pro's/con's.
Old Jul 24, 2009 | 03:05 AM
aldaman's Avatar
x2 ...You could also purchase a set of either front lower or upper control arms to dial in your ride and eliminate the need to use the cam bolts...
Old Jul 24, 2009 | 04:06 AM
Covert_Ops's Avatar
This is great advice.....
Old Jul 24, 2009 | 04:26 AM
Tight_wad's Avatar
Take a look at this link, might help. Why only change upper control arms, or vice versa
