Greasing Teraflex Control Arms..
Old Jul 9, 2009 | 10:08 AM
Hellbound13's Avatar
Did you break it wheeling?
What do you mean "leave it loose?"
Old Jul 9, 2009 | 10:11 AM
09rubicon's Avatar
I changed all the zerks out to 6mm-1 short zerks, I also relocated (swapped the zerk and hex plug) so all the zerks are on the top of the joint. I have no clearance issues now and dont break zerks off. When I need to grease them I just drop one are at a time, grease it, wipe it clean, use a screwdriver to move the joint around a little and get the grease in it, then bolt it back up. Doesn't really take to long.
Red and tacky is fine grease, as are most, I use marine grease, others have there own preferences. I know alot like the white/blue lithium greases.
Old Jul 9, 2009 | 10:13 AM
mkjeep's Avatar
Yep, 90degree on the top zerk on pass side. What I ment was if you couldn't get to the fitting, just take that end of the control arm loose, not leave it loose.
Old Jul 9, 2009 | 10:18 AM
Ah ok. No problems hooking up to the zerks here. I also have a Lucas battery powered grease gun. Makes life easier.
