grill mod question
Old Nov 28, 2009 | 12:11 PM
bradj1964's Avatar
Default grill mod question
Does anyone have a sku number for the self adhesive cable tie mounts for the grill mod? Ive been to lowes, ace hardware home depot , and no one knows what im talking about, even showed them a picture of what I was wanting, any help would be appreciated, thanks in advance!!
Old Nov 28, 2009 | 12:41 PM
8000ft's Avatar
ACE Hardware carries them in their TV cable section, however even after a really good cleaning with acitone mine still fell off in a week.
Old Nov 28, 2009 | 12:43 PM
bradj1964's Avatar
Thanks 8000ft, ill check in that section!
Old Nov 28, 2009 | 12:53 PM
AK4Dave's Avatar
I've seen them in Home Depot. And most autoparts stores have them.
Old Nov 28, 2009 | 02:16 PM
CreepJeep67's Avatar
I got mine at Grainger. I think they only sell to companies but luckily my company was already in their database so I was able to pick them up there. If you have a Grainger close by I would just recommend stopping in and asking to look at their catalog. The gal at my local Grainger was very helpful.
I took a look at the Grainger website and this MIGHT be it...
http://www.grainger.com/Grainger/items/1A872?Pid=search
Old Nov 28, 2009 | 02:26 PM
ratherbskiing3's Avatar
I got them at HD right by the ties. 100 count pack was a deal.
Glue them! I had many pop off. Also, use way more than you think you need!
Old Nov 28, 2009 | 03:41 PM
Smiley88's Avatar
I've done the mod twice - first time used gorilla glue and it worked well except that the backing that comes on the plate itself separated....still happened with gorilla glue.
Second time I used marine expoxy in a tube (clear, cheap, etc.) and it worked. I basically placed the plate down where I wanted them with the self adhesive backing and then 'caulked' around them with the epoxy. Haven't had one come lose yet (10 months).....
Old Nov 28, 2009 | 03:52 PM
mkjeep's Avatar
Grainger sells to the public now, at least in my area.
Old Nov 28, 2009 | 04:22 PM
JCKnauer22's Avatar
i got mine at HD in the electrical section. they should be right by the zip ties and wire nuts and crimp sleeves. i figured out how many i'd need then soaked them in lacquer thinner for a while (maybe 10-15 min). the adhesive backing comes right off and floats to the surface while the plastic sits at the bottom. then i cleaned the inside of the grill with some thinner and used JB weld to attach them. nice and strong.
oh, and if you use the soak method, make sure u wear gloves when you take the pieces out. the adhesive dissolves into the thinner and while you don't notice it at first, you'll get really sticky really quick. not a lot of fun. just saving you the headache since i learned the hard way
Old Nov 28, 2009 | 05:38 PM
JK-Blue's Avatar
I used the rubberized loctite brand superglue, pulled off the self-adhesive pad and trimmed the sides so they fit between the slots making full contact. They've been on 8 months, 9,000 miles and not one has come loose. If you start at one corner you can roll the adhesive pad right off.
