Grinding my calipers this weekend. First time using an angle grinder!
Old Sep 8, 2010 | 04:49 AM
Dronac's Avatar
Default Grinding my calipers this weekend. First time using an angle grinder!
My new Crager soft 8's with 4'' of backspacing are rubbing with about 1/8th an inch of metal being shaved off the wheel at upper part of the caliper (near the edge of the 8 holes). I picked up an angle grinder yesterday and figure shaving my calipers would be safer then running 1/4'' spacers.
Any advice for a noob at grinding calipers? 1/8th of metal won't damage the integrity of the caliper right?
Old Sep 8, 2010 | 05:43 AM
ronjenx's Avatar
1/8" is quite a bit. And now you have a wheel with 1/8" groove in it. Not good.
Pics of both would be helpful to this thread.
Old Sep 8, 2010 | 05:49 AM
Dronac's Avatar
Discount Tire still has the wheel so 1/8th is just a estimate. The rubbing was on the backside of the 8 holes. There is a recessed area where the holes are stamped out and it rubbed on that ridge. It's not a constant groove on the wheel.
My calipers must be huge because these are Crager soft 8's with 4'' of backspacing.
Old Sep 8, 2010 | 06:15 AM
Dronac's Avatar
Good idea in the paint. I'll have to pick some up for the back of my wheels, and the calipers.
Old Sep 8, 2010 | 06:49 AM
LRBolt's Avatar
Practice safe grinding, wear protection.
Srsly...if you've never used one before, those wheels WILL explode. If you get a nick or crack in it, throw it away and get a new one.
Old Sep 8, 2010 | 07:08 AM
Dronac's Avatar
I'm just grinding, not drilling into it.
Old Sep 8, 2010 | 07:11 AM
john smack's Avatar
wear protection!
The grinding is simple.. takes more time to pull the tire off and reinstall it.. no problems with my calipers after almost 2 years
Old Sep 8, 2010 | 01:51 PM
TigerLily's Avatar
I just used a flat file but the interference was only 1/32" or so (parting line on the casting).
Old Sep 8, 2010 | 03:14 PM
07Bubicon's Avatar
Don't get carried away with the grinder either, keep it moving so you dont' gouge the calipers. Good luck!
Old Sep 8, 2010 | 03:24 PM
GoodysGotaCuda's Avatar
Originally Posted by joshzilla
EYE PROTECTION A MUST!!!!!
What?! Huh?! ear protection too
